Hello all,
I thought I would introduce myself to the forum with a quick but about me and mostly why I wish to learn to Tig weld.
I live in the UK where I am currently working on a beach buggy project, so far I have used a MIG to repair the chassis but I quickly discovered that TIG welding was the way to go if your welds will be visable. I also found out that for cutting metals a plasma cutter was also on the list of boys toys as these thigs seem to make cutting metal fun to do. With all this in mind and a bit of digging on the net I came across the Super-200P which in my eyes seemed the perfect machine which would weld and cut pretty much anything made from metal, so I purchased a used one as I could not afford a new one.
The welder turned up a few days later so I hid in may garage with a big grin on my face wondering what I could practice on. I made a quick saddle joint out of 2" tube and set about welding, the machine seemed to be working and I put the metal mess I had created down to lack of experiance, I thought a bit of good practice and knowledge was required. After roughly only a couple hours of use the machine gave up on me so I took off the cover and sighed.
I have worked in the electronics industry for 17 years and I have not seen many things put together like that, I am surprised it survived the journey to me by the courier. before I knew it I had the machine almost totally striped down and began repairing shoddy wiring, dodgy circuit board mountings and pointless earth connection that were secured to a painted surface. It now appears that I have lost track of which wire went where and cannot correctly put back together the unit so if poeple out there with a simalair machine would be so kind as to take some pictures of the insides of there's I would be eternally greatful.
Thanks,
