I will cut but when I quit it blows air out but will not stop so I can weld anymore. I have unscrewed the end and it will quitblowing 90% of the time. what is the problem with my machinge? Thanks for anyones help
Trash in the solenoid, or corrosion. It can be cleaned out. Are you using a water filter in addition to the one that you were provided with?
I have two on the air inlet and have the pitcock draining air all the time. Can this be a me fix it?
Check out this thread on cleaning and stretching the spring a little to fix your problem.
http://www.everlastgenerators.com/fo...hread.php/3374
I do not know about the PP50 however my SC50 has a switch on the front panel that keeps the air on continuously or automatically when the trigger is pulled with a time out when released.
