These machines look like they compare basically identically in terms of power and duty cycle, with the only real difference the shape and the pulse MIG functionality.
I've been poking around the web and reading other threads answering many questions about pulse MIG welding, for instance:
http://www.everlastgenerators.com/fo...e-explained%29
http://www.everlastgenerators.com/fo...-new-model-%29
http://www.everlastgenerators.com/fo...205-Pulse-info
But I'm still left wondering: what would I be giving up without pulse MIG functionality? What would I not be able to do (or do as easily)?
From what I've read, it sounds like the 205P might not be powerful enough to fully use the capabilities of pulse MIG on steel (the 250P would be, but that's bigger than I want to deal with). Once I'm sufficiently skilled (might be a little while!) I plan to get into aluminum bicycle repair/fabrication (thin tubes, high torsional stress), and perhaps the lower welding heat the pulse MIG enables would be beneficial for that task.
Is the 205P worth the extra $200 compared to the 205? My general philosophy on tools is to get the one that will fulfill all my expected needs - I'd rather not buy one then outgrow it in a year or two. I also don't want to spend the extra money for something that gives me no tangible benefit. I also would like to learn TIG welding, which might be even better for bicycle frames, so maybe I'll never use the pulse MIG after all.
Thoughts?
