Project 1 from agent4573. Category: Custom welded Shop tools and improvements
So I picked up a JD Squared Model 32 tube bender, and until I can get the hydraulic ram and all that going I'm going to mount it in the backyard. I live in the Mojave Desert so we get about 2 inches of rain a year. For most of the time I'll have a waterproof bag over it, in the winter I'll probably just unbolt it and bring it inside. Anyway, the stand costs over 100 bucks plus shipping so I decided to make my own. Picked up some raw material from the scrap yard. It sells steel for about 50 cents a pound, so this stand cost me about 18 dollars in scrap steel, 6 dollars for the bolts and 6 bucks for concrete. Add on a can of krylon and I'll be done for about 35 bucks.
I used a few 4x4's to hold the studs in place so they wouldn't move around while the concrete dried.
http://i.imgur.com/HOlxk.jpg
This section of my backyard doesn't really get any use except for holding large garbage until I can get to the dump. I wanted to put a shed or workshop back here, but its only 7 feet wide, so its not really feasible to build anything. It'll work perfect for a tube bender though.
http://i.imgur.com/tBsfF.jpg
Hole dug. Hopefully its deep enough. Again, this is only temporary until I get the hydraulics setup. Should only see a few light bends before that time.
http://i.imgur.com/IkCzp.jpg
It was a pain in the ### to drill 3/4" holes on a tiny little benchtop drill press, but it was a hell of a lot better than doing it with a hand drill. Lots of lube and a stepper bit though and eventually it all worked out.
http://i.imgur.com/ls0Ed.jpg
Here is the base plate. I wanted to make sure I didn't screw up the holes before the concrete set. Used 100 pounds of concrete. Two sides of the hole are basically square and we have solid clay soil out here, so I'm not that worried about spinning the concrete.
http://i.imgur.com/5zYTH.jpg
Here's the vertical post. I cleaned most of the surface rust off and ground the edge out to help with the welding. My mig box is 110 amps and this thing is a 4x4 post with .25" walls to a .25" base plate and top. I'm not even going to attempt it. At this point I'm waiting on a friend to let me know when I can bring it over and melt it together. Hopefully I win the winter contest and don't have to rely on friends for my welding needs.... hint hint....
http://imgur.com/HLAnp.jpg
