So with the new torch on the way, hopefully here by next Wednesday (4 day weekend WOOHOO) I'm in serious thought mode for a cooler. Have a sink in the shop, so city water will work while doing the build.
Started looking at pumps, well, there's where it gets confusing. I look at Procon pumps and see things like 130psi, 6ft head, but things don't add up. If you look at the conversion of head height to PSI, http://www.engineeringtoolbox.com/pu...ure-d_663.html some things are funny.
Which leads me to wonder PSI vs GPH... if I hook up a pump, and it outputs 1qt/min which is what WeldCraft calls for on their WP20, then what difference does PSI make? (assuming of course max PSI isn't exceeded).
I'm just needing to be concerned with flow rate, correct?
I'm sure it's out there somewhere, but I came up with an idea based on an old Mr Wizard experiment. Fitting connected on a board to be used as a scale, set flow of the output to fill a 1qt jar, set it down flat and mark where the water hits the board, distance from the fitting. Turn up the flow till it fills the jar in 30 seconds, make another mark, and when running, as long as the water hits between the marks, I'm in the 1-2qt/min range.
My logic making sense or do I need more than 20 minutes a day sleep again ;)
