Got some hood time today, got a bit confused. Cleaned the zinc off of a piece of exhaust pipe cutoff, tried to run beads around the edge. Keep in mind this is essentially the first time I've TIG'd in 13 years or so...
http://lh3.googleusercontent.com/-L3...64B4F12D7B.JPG
Top right was first, top left was second and the bottom was third. First TIG welds in earnest since I got the machine set up.
Having a bit of an issue with the filler balling. Nice clean arc, slow puddle forming, but the filler is balling and dropping before I can get it into position. Been running between 45 and 65 amps or so, on this and some 16ga square tube.
Welded up a 45 on some 3/4 square tube then propped it up with the peak up and bashed the hell out of it with a hammer. One joint bent, the others broke. OK looking beads, crappy penetration (beveled the edge half thickness, no gap) Again, filler balling up before I can get it to the edge of the puddle. Using 1/16 Lanthanated, 1/16 ER70S-2 filler
Thoughts?
