Plasma Cutting Settings Super 200P
Want to confirm the settings when using the plasma cutting feature on the Super 200P
All Dials set to Zero or Min. except for Current Control
AC/DC set to DC
2T/4T set to 2T
Pulse/DC switch to DC
Mode Switch down (Plasma Cutting)
Air At 65 - 70lbs
I am assuming the Current Control dial is the only dial used to select amperage for plasma cutting
Re: Plasma Cutting Settings Super 200P
That is correct.
Also, for thinner metals, sometimes under 60PSI will yield a thinner cut. On aluminum make sure you angle the torch say 45 degrees to avoid spatter in the tip.
When does the digital readout display the amperage?
When you set it with the AMPs knob. It is really just to assist in setting the amps.
