Hey guys, just got my Super Cut 50, UPS dropped it off today, acquired it from you guys on Pirate4x4 (same screen name), opened it up and looked it over. Sadly it came though with a cracked front and rear plastic cover (the ones the straps attach to). The front is cracked all along the bottom and side, and the rear, the plastic snapped off around where the screw runs through it. How do I go about getting new ones?
Good news though it works!
Performance, or whoever wants to chime in, I've got a few questions: Is the potentiometer for the amperage supposed to only go about 3/4'ths on the printed scale? My amp range in the display is 12-53 is that within spec? Are these only contact start, touch the workpiece and either pull back a bit for stand off, or drag cut? TitanWinch had a video cutting 1/4'th plate with the SC50 at 30amps, however mine won't completely punch through until 40amps....is there anything I need to gap or adjust? And lastly, when you shut the power off, is the display supposed to stay on for 10 seconds before it too powers down, as mine does?
I took pics of the unwrapping and all steps through setup and am going to do a thorough review on Pirate as I told Alex I would. Thanks for any help guys.
