The Green Hornet Has Arrived
Yesterday I got home to find a box on the porch from EVERLAST. First thing I noticed, the Box was in relatively good condition. Side note: I ordered a Optima battery delivered by FedRex (Fed Wrecks) the box was destroyed but the battery was ok. Usually the first thing I notice from now on is box condition. I was then surprised to notice it wasn't as heavy as I expected. I quickly unboxed my green hornet to find it in excellent condition. I then inventoried the parts and began to assemble the moisture separator. I didn't like the way the air tube connections threaded into the body of the separator, the separator on my compressor is connected in the same fashion and the hose fittings are tapered pipe thread and seal well. These fittings bottomed against the hex above the threads which makes me think the separator body was tapped too deep, or the hose fittings are incorrect. I will be testing out some of my line fittings to see if they fit any better. At this point I am not able to spark an arc yet as I am still awaiting the arrival of my air compressor moisture trap. Once that’s in I'll mount and connect it. In the mean time I will be stopping at the local Home Depot to purchase a plug to match my 220v outlet.
I can't wait to try this machine. I installed an ARB rear locker in my Tacoma and will mount the air compressor in the engine bay once I fab a mounting plate that will be my first project. Then a friend needs a blank flange for a project on his fox body mustang. After that - - - well I won't bother you all with that but I'm guessin the to do list will grow.
