What Mig size for lots of 3/8 & some 1/2
Thinking about getting a mig for doing lots of 3/8 thick material and also will do some 1/2 inch stuff with it, currently have an AC buzz box for that size of material but want to switch over to mig. Question is: what are the upper limits for the 200 A and 250A mig machines (thickness wise). My average weld length is about 12 to 15 inches before I stop for a smoke or what ever, so duty cycle could also be an issue.
Bigger would seem to be better
Quote:
Originally Posted by
WAYNESWORLD
I would also recommend the larger unit if you are going to burn a lot of wire. The larger spools are more cost effective. I like to buy mine in 45#.
Wayne
Upon reflection, I think you are right, 1/2 inch requires lots of heat for proper penetration, and I want a mig welder that will do that with ease, rather than pushing it near it's upper limit. I have had a Clarke 130 EN for years and it is great on sheet metal and stuff up to 1/8, tacking etc. but now I want something on the order of the imig 250 to replace the old buzz box (thunder bolt)which has seen lots of use and abuse.
