So the 2lb. roll has a small hole that fits the shaft and rolls fine.
I'm wondering if there is an adapter that I didn't get with my welder to load a larger roll with a 2.5-3" hole in the center?
Max roll size is 12 pounds. When I bought a 12# roll it installed just fine, with no adapters. What are you working with?
The metal plates have a depressed center which go into the sides of the roll. Be sure to put plenty of tension on the spring...but not too much.
Plate or plates? I only have an outer disc that is depressed so I guess I'm missing one? maybe thats why it doesn't roll so well....
I ended up using the core of a 2lb. roll to make it work.
http://i33.photobucket.com/albums/d8...t/IMG_1106.jpg
http://i33.photobucket.com/albums/d8...t/IMG_1110.jpg
http://i33.photobucket.com/albums/d8...t/IMG_1111.jpg
http://i33.photobucket.com/albums/d8...t/IMG_1115.jpg
http://i33.photobucket.com/albums/d8...t/IMG_1118.jpg
You should have an inner one as well WHERE the rod is bolted on that holds the small spool. It is fixed to the side of the welder.
