problem with new PowerTig torch
I just received (11-25-09) my new Power Tig 250EX and discovered a problem while setting the machine up for trial welds. First I welded in the ARC mode with no problems. The welds were beautiful and easy to make. Then I set the machine up for DC tig welding using the remote foot control. I could not get a stable arc and kept burning up electrodes (1/16" 2% thoriated, pure Argon @15CFH).Talking to Mike in customer service, he suggested using the torch only and eliminating the foot control for now. I did what he suggested and had the same results. After some brain storming with Mike and some experimenting on my end, it turns out that the torch is not connected to the argon line correctly. I has been set up so that the argon does not come out of the ceramic cup but instead comes out one of the cooling water lines. I will contact customer service and have the send me a new torch. If any one has problems establishing a good arc and burns up electrodes you may want to check and see if the torch is plumbed correctly so that argon comes out the ceramic nozzle and not one for the cooling lines. Today (12-7-09) I ordered a water cooler for my Power Tig. In addition to these machines I own a Cut 50 plasma cutter and just love it. I have it mounted on a cart by itself so that I can move it around as needed. As soon as I figure out how to send digital pictures I will send a picture of the set ups I have.
Ditto - argon connector came attached to water hose
Received my new 250EX on 01-26-10, and discovered that the torch assembly had the same problem as previously stated, with the argon connector being on one of the water hoses.
It was on the water inlet hose and not wanting to use a worm gear hose clamp I carefully removed the crimped strap and reused it when installing the barb connector on the proper hose.
Simple deal. Use care and slightly bend the locking tab only enough to release the strap end. Relieve the tension on the strap by bending the loose end up and then remove the parts. Before reinstalling the strap clamp, open the crimped section to lengthen it for easy re-installation. When it's installed on the correct hose, hold the end of the strap down and lock it down with the tab.
To re-tension the clamp I carefully used a pair of end nippers, because the surfaces are parallel, to tighten up the crimp. Not enough force to cut the stainless steel but enough to close it up properly.
Went out today and visited the closest dealer which is Airgas in Longview, WA. Got a "200" tank (250 cubic foot) filled with argon for $245. It will be $55 to refill which is only $10 more than they get to fill their "150" tank. Bigger is better.
Now I've got to learn how to use this very nice 250EX.
Rolynn
Clatskanie, OR
