Project 4 Mean Green Contest, SeanMurphy265, Stage Backdrop.
This will make more sense when it's up. This is for a church; to hang fabric or curtain so you can have a backdrop on a stage. The pipe will fit inside volleyball poles they already have. The volleyball poles slide inside a base with wheels, and can be rolled around. The tube is 2x2-14gague so it's not too heavy. I drilled 1/4" holes every 2' for the eye bolts. I welded the nuts so the eye bolts can be removed. It's basicly a 20' curtain rod! The pipe is 1" schedule 40 with holes drilled to match the pre-existing holes on the volleyball net tubes. I'll hang it up tomorrow and post some more pictures. Not much too it. I used my Imig 200, drill, and cut-off saw.
http://i32.photobucket.com/albums/d2...5-10153429.jpg
http://i32.photobucket.com/albums/d2...5-10153438.jpg
http://i32.photobucket.com/albums/d2...5-10153656.jpg
http://i32.photobucket.com/albums/d2...5-10165619.jpg
http://i32.photobucket.com/albums/d2...5-10175926.jpg
http://i32.photobucket.com/albums/d2...5-10181611.jpg
