1996 Toyota Tacoma made into an off-road racer/mall crawler
Well, it's still very much in progress, and has a way to go. If you want to look at the FULL build thread go here:
http://www.nc4x4.com/forum/index.php...ild-up.100879/
I'll just start with CURRENT pictures, and update as I get further along with the build. More pictures from start to current are in the above link.
Running Ruffstuffspecialties axle housings, with FJ-80 internals and factory E-Lockers. Gear drive t-case, 4.7 gears in the rear case, going to buy an adapter to run dual t-cases so I still have a factory low range gear.
Long travel "baja" leaf springs in the rear with 17" travel Bilstein 4 tube bypass shocks
3-link with coilovers in the front (still have to buy the steering knuckles and shocks)
37" tires
All tube/fabrication work done by me.
Glassworks Unlimited bedsides and front fenders (bought used for less than 1/2 price)
Front tire is not on the axle, it's just sitting there. Front axle will likely be moved rear some.
http://i1120.photobucket.com/albums/...4791956878.jpg
http://i1120.photobucket.com/albums/...4792222479.jpg
http://i1120.photobucket.com/albums/...4792130265.jpg
Already pulled the t-case back out, need to order the adapter to run duals.
http://i1120.photobucket.com/albums/...4105463252.jpg
