My PP 205 plasma torch?
http://www.ebay.com/itm/Plasma-cutte...#ht_3658wt_802
I have one of those n but it wont work on my s45 torch . what torch do you have. the have one for the s45 but sorta pricey to me. I buy stiff from them the have good prices but not on the circle cutter setup for the s45
no its the make of torch s45 . http://www.ebay.com/itm/S25-30-S45-T...item27bc434f34 this is the one that fit yours at 3 shop rivers to me sorta pricey i just bought some consumables from them i have the s45 also on my machine they was the cheapest on consumables if you just got the plasma make sure you get a good moisture filter trap makes them cut a lot better and saves on consumable's
depend is your air dry or do you have a water problem when it blows air
seems dry. I live in NC if that makes a difference. Seems to cut fine.
this is what i use on my air compressor but i also paint some times at my shop so got the combo water and oil separators , http://www.eastwood.com/moisture-and...&parent_id=532 the ones on ebay are junk bought one an in about a week it started leaking , so spent the money on a good one from this place if you are not painting just get the moisture one http://www.eastwood.com/moisture-separator.html they have other one's too but some can be expensive I see the post on forum most problems with the plasmas is from contaminated or wet air. plus dry air also makes you air tools last a lot longer. they also have 1 on at harbor freight but the rating on it from buyers show it a crappy made unit
