So no that I got my pp256 working I can finally lay down beads on aluminum in a straight line. I'm welding aluminum that's about 0.04" thick with a 1.6mm tungsten and a #5 lens. The aluminum is bent in a 90degree angle and I would like to lay small bead into the corner to strengthen it. I started with about .25" stick out but I couldn't get the arc concentrated into the corner. I increased the stick out to about 3/8" and it helped but it still wouldn't focus the heat into the corner. I end up with a huge filet weld. Any suggestions?
