CGCINC... Bike Rack for My Nissan Titan Utili track
I'm planning a trip for this summer and needed a 4 bike, bike rack so I made one to slide in and out of my truck.
I used 1 1/2" 16g tubing. I mad a sample of the angle I would need with some PVC that was lying around and then took that and the pipe to a muffler shop up the street and they bent the tubing to my pattern.
My Nissan Titan has the Utili-track system in the bed and I have a tool box that will slide in and out so I figured I would use the same system to make it easy to remove but sturdy enought to hold four bikes on a road trip.
Pretty simple but thought I would share...
3/8" plate block with bolt welded on to slide in the rail..... 1 1/2" square tubing cross bar..
http://i33.photobucket.com/albums/d8...C/IMG_0555.jpg
A bolt with tabs welded on to lock in the front rail..
http://i33.photobucket.com/albums/d8...IMG_0527-1.jpg
Cut to size and angle..
http://i33.photobucket.com/albums/d8...C/IMG_0534.jpg
2x4 spacers to keep the distance I need while welding..
http://i33.photobucket.com/albums/d8...C/IMG_0552.jpg
Stainless tubing to weld in where the tires will rest...and for looks...
http://i33.photobucket.com/albums/d8...C/IMG_0549.jpg
http://i33.photobucket.com/albums/d8...C/IMG_0551.jpg
1/4" bar to hold the front distance..
http://i33.photobucket.com/albums/d8...C/IMG_0550.jpg
Start welding...
http://i33.photobucket.com/albums/d8...IMG_0535-1.jpg
http://i33.photobucket.com/albums/d8...C/IMG_0553.jpg
