Tracking down the cause of plasma cutter interference
So far so good, the plasma cutter is working alright. However, the PowerPlasma 60 is causing interference with the motor controller and forcing a restart of the motor controller when the plasma cutter is triggered.
The pc seems to be fine, its 5 feet away and optoisolated, and the parallel port doesn't seem to be the issue.
Here is the setup. A generator powers the plasma cutter and air compressor. The motor controller and PC are powered through an inverter. The plasma cutter is grounded at the generator through the third green wire and by a wire connected to the back of the case staked to ground. The plasma cutter cable runs along with some of the motor wires for several feet, as they are going to the same place. They should be separated by a few inches but the motor controller wires are not shielded.
The manual mentions that the plasma cutter is a pilot arc device, but its very difficult to gauge if it is working. HF starting with a cnc maching could be the problem but I don't know how to test. The internals of the machine has a pilot arc circuit and a HF start circuit. I might just manually disable the HF start and see if that fixes the problems. In theory it shouldn't be on anyways, but the front panel layout is not very helpful. Also, according to the manual, the Auto/Standard switch is suppose to be a toggle vs. momentary switch, but I couldn't tell the difference.
So, is there an obvious fix? Is the PowerPlasma 60 actually a pilot arc machine? How about inductance on the wires?
