Project #4 Dyethor Gasoline processing table
Hello. Today my project is a gasoline processing table made out of aluminum.
All the square tubing is 1"x1"x 1/8" 6061.
The channel is a 3" x 1.5" 6061.
The angle is 1.25" x 1.25" 6061.
The sheet is 1/8 thick 6061.
This table is used to first hold gas then fillter is out and send it to a big holding tank, which is usually 1000 gallons.
This first picture is cutting the metal on the band saw. I like to use this sliding square to set the proper dimension, it gives perfect repeatable results.
http://www.everlastgenerators.com/fo...4&d=1330042161
This is all the metal cut and awaiting to be welded into the table frame.
http://www.everlastgenerators.com/fo...5&d=1330042170
Here is the results of the first critical weld with my new power tig 225lx.
http://www.everlastgenerators.com/fo...6&d=1330042181
The second weld ready to be welded.
http://www.everlastgenerators.com/fo...9&d=1330042214
Two legs in the 90 degree clamps waiting to be welded.
http://www.everlastgenerators.com/fo...0&d=1330042224
