tig welding aluminum with DC only tig....
i thought i remember reading that you can weld aluminum with a dc only tig with helium?
also if i remember reading right, it will only work for thicker stuff is this true or can you do thinner?
if the above is true, is there anything else you have to do to make it work, ie different rods, more or less gas, switch polarity,ect????
