Reccommend me An Everlast Tig Please
Hey guys, new to the forum. I'm currently in the process of building a twin turbo trans am. I have everything done minus the turbo kit, and I'm now looking at buying a TIG welder to fab up my own kit.
I will be using 1 3/4 16ga 304 stainless tubing for the headers, and 2mm thick 3" aluminum for the downpipes.
Here are some examples of what I'll be doing. Let me know what series Everlast TIG welder you all recommend me to use for this project. BTW, I'll be doing this in my home. Thanks!
http://inlinethumb62.webshots.com/42...500x500Q85.jpg
http://inlinethumb54.webshots.com/43...500x500Q85.jpg
http://inlinethumb04.webshots.com/32...500x500Q85.jpg
http://inlinethumb58.webshots.com/43...500x500Q85.jpg
http://inlinethumb49.webshots.com/22...500x500Q85.jpg
http://faststreetcars.com/imgs/turbo-setup.jpg
A few "add-ons" to consider with the machine purchase.
Based on the pictures you provided, I wanted to say NICE JOB SO FAR!! You are also going to be looking at a purge setup to get those headers welded to their max strength, I would advise that you use the search function on this forum for more info. Are you out there Jakeru? This is irrelevant to which machine you will ultimately end up buying, but I wanted to mention it in case of budgetary concerns. You should be able to put together a decent purge setup for under $100.00. Plus, I would recommend a torch upgrade, watercooler, if in-budget, and a champagne nozzle that will allow you to stick that tungsten way out there for getting into the tight spots on the headers. Just another $0.02 worth of advice. If you go 200dx, your total outlay, including welder, cooler, wp20 torch, purge setup, and champagne nozzle should set you back UNDER $1800 total, plus shipping on the periphals from other vendors, and you'll be setup like a PRO!! Then it's just a matter of practice before you start making the beautiful welds that your setup deserves. You can PM me for more info on the purge and champagne nozzle. Good Luck!!
By the way, What year is the TransAm? I had a '77 with a 400/4speed. One of my favorite cars I've ever owned. 'til I spun a rod bearing on Interstate H1. Yes, I owned it in Hawaii.
