Anyone use .020" or .040" tungsten for anything?
So, now I have my welder on the way, I've got a TON of subjects to start discussions about on the forum. First on the list, has anyone used the smallest diameters of tungsten with their Everlast machine. Just about everyone I know (myself included) uses 3/32" tungsten for the majority of their welding needs. From what little experience I got with my old Linde with a weldcraft WP20, and water cooler, 3/32 filled the bill for 90% + of everything I welded. I think I tried 1/8" on some heavy stuff, but that was the welding machine with bad mojo, and it would trip the breaker at anything over 225 amps or so. plus you're pushing the limit of what a weldcraft brand can handle, amperage wise. There are other WP20's that will take 250++ amps all day long, just not a weldcraft. Back to the lower end. I bought the .020 and .040 just to have in case of that special situation. I tried out the .040" on some razor blades with decent results, but could do just as well with a 1/16 sharpened to a long taper. So the question is: Have you used small diameter tungsten? If so, what for? Thanks.
