I have my new cooler for my EXT sitting here and have a few questions
1- There is no power plug on the back of the EXT for a cooler, what is the best way to wire it in?
2- If the cooler is not interlocked with the welder and needs to be switched on manually each time, how does the flow switch in the welder protect the torch if the cooler did not get switched on?
3- Is RV antifreeze OK in Everlast equipment?
4- The barbed fittings on the welder are 8mm the ones on the cooler are 6mm. Where do I get 8mm fittings for the cooler? I prefer to not have extra adapters/clamps in the lines.
