Powermaster 226 questions
I recently purchased a Powermaster 226 and this weekend finally finished setting up the cart, tank, air/argon/dryer switching and tried my first attempts at Tig welding aluminum. Considering I have not tig welded It was pretty sucessfull. I had a friend who did many years of Tig welding coaching me but inverter technology came after his welding days ended. I have a few questions about the settings for AC tig welding of aluminum. The manual that came with the welder was not very well written but the manual off the website was much better but I still have some questions.
1) AC Balance the manual says "More DCEN is preferred for cleaning oxidation in aluminum" I thought electrode negative is more penetration and positive is for cleaning? The manual goes on to say More DCEP is preferred for penetration. Is this backwards?
2) AC Balance when you go to a higher percentage rutning the dial clockwise does this give more penetration and less cleaning?
3) I am using the foot pedal so I turn the pulse current all the way down and set max current using the base current on the machine but there is also a pot on the foot pedal that seems to limit current as well, do you use both or just set foot pedal to max and use the base current setting on the machine?
