warranty question
i have an i mig 200 and a powerultra 205 and i was wondering if the flow gauges that came with the units have a warranty? today while i was welding some brackets the body of the flow gauge cracked on the back and leaked around 400psi of ar/co2 before i caught it
Ancillary items are 6 months. When did you buy them?
My pressure gauge failed and started leaking the second time I opened the bottle valve. I just put another gauge on and kept working... I never considered the gauge had a warranty.
If a gauge breaks on a weekday that's a better thing if you only have one gauge, you can run out for a low cost gauge, they work fine. Happened to me once, and in my case, just like Zoama585, just swapped with another gauge. Since you have two unit you can interchange yours for now and contact sales for warranty info.
When you figure a low cost Clarke price for $20-40, sometimes it's a good backup option. Then swap ours out so you have a spare. Never hurts to have a backup.
It's to bad, but gauges today seem to be becoming disposable like everything else.
i swapped over to the other gauge but it was also leaking(first time out of the box) but i messed with it some and got it to stop. the gauge i was using is 2 years old so i guess i'll do like you suggest and go buy another as a backup
