Powermaster 205 Plasma problem
When I got my Powermaster 205, it worked great. Now I've used it a few times and the plasma cutter is barely working. I did a little bit of DC TIG welding on steel last week, Saw some slow pulsing of the Plasma of the TIG welder, it seemed to increase and decrease in intensity a bit every couple seconds, not sure this is normal.
The bigger problem is plasma.. this weekend I switched back to Plasma. When I first moved the torch to the metal to be cut I got a big spark before pulling the trigger. As I started to try to cut, I got airflow, but instead of plasma I just a of couple short popping arcs.
I changed to a new tip and electrode, upped the pressure from 60psi to 65psi and increased the amperage from 25amps to 30amps and tried again... This time I got a plasma formed, but it seamed weak and ended up blowing back across the metals surface after an inch or so. Checked the tip and found it blown out.
Checked all connections, changed the tip and electrode again, upped the pressure to 80psi and increased the amperage to 35amps. This time got a good plasma, but still a bit weak compared to my Miller plasma cutter set at 15amps. The plasma cut ok for about 8 inches then I could tell the tip blew out again.
Not sure what to do next, I'm out of consumables, will try and pick up some on the way home Monday.
These are the tips:
http://cdn-3-service.phanfare.com/im...3fcafaad386a_1
This is the connections and settings, everything centered except Base Current at 35 for last attempt.
http://cdn-3-service.phanfare.com/im...1f3556c4e584_1
