This is project 1 from Trip59, Spring project - my take on a welding cart (version 1)
So after lugging around the welder for a while, I determined I needed a cart when I made the switch from flux core to solid wire and added the bottle. I had a bunch of scrap angle, mostly bed frame, but didn't like any of the ideas I saw or came up with. A sale at Harbor Freight caught my eye and I picked up a pair of carts: http://www.harborfreight.com/three-s...cart-6650.html (I had to pull the image so I could include all the project pics)
I had an old three drawer toolbox I've been carrying around since my days in the junkyard. The movers smashed the lid, and I never could get it straightened out quite right. I figured I'd incorporate it to provide for wrenches, tips, grinding wheels, etc. and make it a service cart.
Due to cost and ease of use, I picked up a small bottle from Tractor Supply, C25. I had the idea the moment I saw the cart of how I'd set it up. Box on the bottom, notch in the center shelf, welder on top, cords wrapped around the handle.
http://lh5.googleusercontent.com/-6z...g/s640/401.jpg
I traced and cut out the semi-circle with an air nibbler and body saw, saving it for later so I could weld it back in if I made a different cart ;) Well, how to hold the bottle in securely? How about a rod through the rolled edge?
http://lh6.googleusercontent.com/-si...Q/s640/403.jpg
Fits snug, stays in, comes out when needed and the bottle just rocks out.
All together, but I didn't like that things could slide around and fall out or hit the bottle
http://lh3.googleusercontent.com/-PM...Y/s640/405.jpg
Yes, I could have welded a piece in, but I didn't want to burn off all the paint and have to re-paint it, I had other things to move on to. Cleco clips and rivets to the rescue!
http://lh5.googleusercontent.com/-1o...M/s640/411.jpg
http://lh5.googleusercontent.com/-ok...Y/s640/412.jpg
http://lh6.googleusercontent.com/-Br...0/s640/413.jpg
You can see the toolbox open in the pic above, here's one of it shut and of the whole cart
http://lh5.googleusercontent.com/-4X...A/s640/406.jpg (yes, that was before the guard around the tank)
http://lh5.googleusercontent.com/-ku...g/s512/404.jpg
The cart has served me well, though I've been thinking about how to re-work it when I pick up an Everlast. I am probably going to use the other cart I bought at the same time, placing the welder on the bottom shelf, raising the middle shelf and making a consumables holder in part and a mount for organizer boxes, and leaving the top open for work/temp storage. I'll likely run the bottle out the top of that one, as I'm not about to try to deal with 20 or 40 ft bottles of argon...
