Advice on Welding HF Trailer Kit
My current "big project" is a hovercraft. One of the things I'll need to use it, is a trailer to transport. I didn't want to buy a trailer large enough as it would cost as much or more than the hovercraft.
So, when I started the project about a year ago, I bought a Harbor Freight trailer kit that bolts together.
I was thinking that it would hold up a little better if I welded the joints in addition to the bolts.
Question 1) Is it worth while to weld the trailer
Question 2) If it is worth while, should I disassemble it to grind the powdercoat off where I can to weld it, or just grind it off while assembled?
At some point before I use it, it will need an extended tongue and a wider platform. I haven't figured out if I should do that in wood, or frame in angle and then use a wood deck.
Any thoughts on that are welcome.
