Welding small diameter rod
Some of my home project require me to weld small diameter rod to pipe/flat stock etc. and my welds always look bad. Is there a trick to welding the circumference of small diameter rod (1/4")? I have a PP205 and use the supplied W26 torch which is big, heavy, bulky and hard to maneuver around the small diameter rod. I usually tack at least two sides then sort of tack the rest of the rod to the other piece, but it does not look nice. When I say it does not look nice I mean it not a continuous weld. Any tips are much appreciated.
