Project #10 From Jason: Stripped Lug Bolt.
So here is a little project that called my attention. When the owner was attempting to change brakes, a lug bolt stripped out and would not budge. I tried everything that I could to get this out and finally came up with a simple solution. Time spent was a couple hours of fighting.
First new rotor/hub
Http://www.projekt6.com/jackal/StrippedLug/100_2030.jpg
So the start of this was put a lug extractor on it... Should get it out... NOPE.. I was putting all my strength into it when I heard SNAP.. Thinking sweet I got it to break out of there.... NOPE.... Split my new lug extractor down the side... Craftsmen so it got replaced. Problem is I broke one and didn't get it to budge so I didn't want to snap yet another..
I decided I would try a chisel to break the head and No go as I assumed. Then I proceeded to drill it out with the expectation it would fail and sure enough I had enough after not long.. That left it here
Http://www.projekt6.com/jackal/StrippedLug/100_2033.jpg
I decided since I did not have access to an oxy-ace at this time, I would simply pull the hub and caliper and wheel and everything else at once and then finish the brakes. After I would get the wheel free..
Http://www.projekt6.com/jackal/StrippedLug/100_2029.jpg
Brakes done
Http://www.projekt6.com/jackal/StrippedLug/100_2037.jpg
My plan of attack now it drill through the old hub and relieve the lug bolt.
Http://www.projekt6.com/jackal/StrippedLug/100_2028.jpg
I drilled just until I hit the wheel..
Http://www.projekt6.com/jackal/StrippedLug/100_2032.jpg
and off..
Http://www.projekt6.com/jackal/StrippedLug/100_2034.jpg
Http://www.projekt6.com/jackal/StrippedLug/100_2035.jpg
Http://www.projekt6.com/jackal/StrippedLug/100_2039.jpg
Next time, I will just pull the wheel off all together and go at it this way again if the extractor breaks. A brand new lug bolt was used in place of destroyed one. Tools were drill, drill bit, hammer, extractor, sockets, ratchet and chisel...
