Project #8 From Jason: Transmission Limited Slip Diff Install
Here I installed a limited slip diff into a friends supposedly rebuilt trans that he purchased after tearing up his first gear.
I will state that this is by no means a guide to do this as you need to check bearing preloads and such which I am not covering. Also this is not going to show everything that is done to do this as I didn’t take pictures of every step or bolt.
The reason was as I mentioned, my friend destroyed 1st gear and needed to rebuild the trans or get a new one. A LSD is always a nice upgrade and will make his gears last a little longer. The time spent to install the LSD was a couple hours total. I think it was around 3 or 4 but that involved open to close of the trans and we wiped down the inside. I have not been keeping track of time much for my projects as I usually work on more than one at a time or one right after the other and make a day out of it. Being unemployed right now is giving me a bunch of free time.
So first I removed the shift selector and bottom cap.
http://www.projekt6.com/jackal/LSD/100_2525.jpg
http://www.projekt6.com/jackal/LSD/100_2526.jpg
Then removed the 5th gear cover and pulled all the gears/syncros after removing the 5th gear selector.
http://www.projekt6.com/jackal/LSD/100_2524.jpg
http://www.projekt6.com/jackal/LSD/100_2527.jpg
To get the gear that you see by itself on the far side, I had to modify the puller to fit in and get it.. A angle grinder and flapper wheel does a good job.
http://www.projekt6.com/jackal/LSD/100_2528.jpg
There was more bolts to remove and what not to get the case open but anyways here is the case opened up. Looks pretty dirty in there for a fresh rebuild however everything looked to be in good shape.
http://www.projekt6.com/jackal/LSD/100_2529.jpg
Next we pulled everything out to get the diff out.
http://www.projekt6.com/jackal/LSD/100_2531.jpg
http://www.projekt6.com/jackal/LSD/100_2532.jpg
The next job was to pull the bearings and small plastic gear off the diff. Then remove the rivets and finally the ring gear. I didn’t get any pics until removing rivets and ring gear. To get the gear off I had to press all the rivets out and then press the ring gear off. I tried to just press off the gear but that didn’t want to work smoothly.
I didn’t take pics until I actually had started on the rivets but anyways I first drilled all the rivets with a 6mm bit.
http://www.projekt6.com/jackal/LSD/100_2533.jpg
After you can go back and drill with a 12mm bit
http://www.projekt6.com/jackal/LSD/100_2535.jpg
