Mig 200 wire feed problems
My 200 will quit feeding wire and will spool out between the roller and entrance to gun liner. It then shorts out and arks inside the case. I have to pull all the wire out of gun, clip the wire out the spool and rethread it in the roller and then the liner. It happened four times in ten minutes yesterday. I was running higher voltage and wire speed then I normally run because of thick material. I tried different tension settings on the roller but it didn't seem to make any difference. The wire was burnt back to the tip each time but I had good direct ground and clean metal. What am I doing wrong.
