8 Attachment(s)
PowerPro 205 Arrived yesterday also!
Hey All,
When I got home from work last night, I was Greeted by my Everlast Box as I walked in the door!
My brother in law signed for it, since I wasnt home, luckily there was no damage to the unit itself it seems so far!
a neighbor saw me carrying the box out to the garage, and said " i hope there isnt anything fragile in that box, the UPS guy just tossed it off the back of the truck!"
I was like, uhhohh..here we go! but, the foamcell packing did its job well, and the unit is undamaged.
see pics below.
anyway, once I got it unpacked, i figured I'd try the plasma cutter first.
it seems like the pilot arc feature is a bit spotty, it dont fire at full power consistantly, and sometimes takes several trigger pulls before it actually works properly, but once it does, it sliced right thru some 3/8" steel stock i had laying around like a hot knife thru butter!
im thinking the points thingy may need adjustment, ill poke around the forum abit before i call one of the guys about it.
next i tried the stick welder.
since i have never stick welded before, all i did was pretty much make a mess with some 6010 rods i got from a friend, but at least i did verify that it does work.
then i moved on to the tig. ( the main feature that i bought it for)
again, i've never tig welded, but after a handfull of times of going to start, and dipping the tungsten right into the workpeice, i was able to get the beginings of a bead like formation! lmao
i only had a bit of argon left in a small tank i normally keep around for the small 110v mig machine i have, so i only got about 5-10 passes before i ran out of gas, but i took a couple crappy pics with my ipod ill post in a bit.
friday im getting a bigger argon tank, and this weekend ill get some proper practice material and get to work!
