Cast iron welding clip. Anyone ever tried it?
I've made a few cast iron weld repairs over the years, using nickel based stick, brazing with brass rod, and yes, even welded a cracked exhaust manifold on the truck with 7018 and it held for 10 more years till the truck was sold:D. But as a tig noob, I was pleasantly surprised to find this clip.
http://www.youtube.com/watch?v=-uqi9wCmBgw
This guy has posted a few videos using unconventional methods, including using flux-coated aluminum stick rods with DC TIG. I hever thought of using piston rings for filler metal, but think about it, once the carbon is cleaned off, It's probably some of the cleanest cast iron a guy can find.
Preheat is generally the rule.
OH CANADA...:P Always wanted to say that:D:D. To answer your question, yes, preheat is generally accepted as a necessary. Cast iron is some real funky stuff. As Jody correctly says on his site, there are so mant different situations that affect the properties of the metal, that sometimes it goes like a dream, sometimes not. There was another clip on youtube of a guy repairing a notorious crack on a cummins diesel truck block, that involves running the engine, draining the coolant, preheating the metal, doing the weld, then immediately refilling the engine with the still warm coolant and restarting the engine, all to keep the thermal properties in a range where by the stresses built up during the welding process are allowed to properly dissipate. Enormous pain, but by the looks of it a successful technique. This is the type of stuff I would like to get into.
