pictures of TIG aluminum head need HELP!!
Hi Folks, I've been playing with the idea of welding up a blown spark plug hole in a ford v10 head. I got a scrap head from a yard, and made the spark plug hole so it looks like tha one I'm needing to repair. here's what I got on attempt #1
http://i985.photobucket.com/albums/a...65/head033.jpg
looks awful. any ideas??
3.
cylinder head tig setup pics 2
Here's more detail on the setup. I currently have a WP20 water-cooled torch, I used a gas lens with a #7 cup and 3/32 thoriated tungsten. I tried to stick the tungsten waay out there to reach all the way to the bottom of the hole.
http://i985.photobucket.com/albums/a.../head044-1.jpg
Next I used my cherry picker to suspend the head over my turkey fryer burner for preheat. If you've ever used a turkey fryer, you know that the 6" diameter burner is capable of throwing some serious heat:D I kept the head about 20" above the head for even heating. I used a IR thermometer and pointed a laser at the work area, and slowly brought the head up to about 220F. The comment about a piece of aluminum this big being a heat sink was spot on, I found that if I got just the area of concern up to temp and removed it from the heat, by the time I moved, the heat had dissipated throughout the rest of the head:mad: it took about 30 minutes to get the WHOLE head up to 200F.
rundown on aluminum head tig
So, until my situation changes for the better, and I actually get my EVERLAST welder(s), here's the machine I'm using to learn TIG
http://i985.photobucket.com/albums/a...65/head046.jpg
Big, old, heavy sine-wave, transformer machine. Just checked out as good for 380 amps on a load bank, but I'm limited to about 220, due to having only 50 amps available in my shop. There's no AC balance or freq control, but it has these 2 controls.
http://i985.photobucket.com/albums/a...65/head047.jpg
They do focus the arc somewhat, but not like a modern square wave machine does.
So Here's the rundown in a nutshell.
-Fully cleaned down to shiny aluminum using dedicated aluminum cleaning tools
-Rinsed and degreased with Acetone and Denatured Alcohol
-Copper backing plug cleaned and fit to the hole
-Preheat the head to 200F
-75% Helium/25% Argon mix -expensive
-WP20 water-cooled torch
-3/32 thoriated tungsten, gas lens with #7 cup
-Big Ethyl, my monster TIG power source
Really looking for suggestions, and more importantly, WHICH Everlast Tig machine will be most suited to this type of work? Thanks in advance.
Thanks jakeru! more info.
Thanks for the response, I had a few questions. First, the reason I couldn't chamfer the hole is because of the fear of breaking into the water jackets, as this is why i've been led to believe that most head shops will not weld this particular injury. I wanted to ask if you've ever tried a "champagne cup" type of cup and if maybe this might work better? Are those cups available in pyrex so maybe a guy could see what he's doing? You were spot on that I'm a total noob so I really didn't know what to expect, but the black crust was pervasive, and elevated to the level of soot when i tried to break through the hole. interestingly, before i made a mess, i could get the tungsten all the way to the bottom of the hole and make the arc go and stay where i wanted it to, it just wouldn't break through and allow a puddle to form. thanks again!
