Drive Roll U-Groove Single (Aluminum and Bronze)
SKU# EV-DR-UG-0608
This bottom-mounted U-groove drive roll for Aluminum and Bronze wires fits multiple Everlast MIG welders equipped with a two-roll wire feed system. In this configuration, the lower drive roll feeds the wire, while the upper roll is typically a flat-surfaced idler that applies pressure to hold the wire in the lower roll’s groove. Only one U-grooved drive roll is required. Select the appropriate drive roll for the type and diameter of wire you are using.
Keep in Mind:
  1. This is a .023"-.030" drive roll which may have markings of 1.0-1.2mm equivalent groove sizes.
  2. It is U-Groove for Aluminum and Bronze solid wire feeding use.
  4. .023" and .025" size wires use the same groove.
Special Note:
  1. This drive roll requires a higher IPM output wire feeder. This is not advised for use on 120V with any dual voltage machine or 120V single voltage machine. It also should not be considered for use with machines less than 600 IPM maximum wire feed speed. Feeding this size wire in the MIG gun, even with a teflon liner will likely cause issues. Use only with the proper liner, a short MIG gun length and a graphite or polymer/teflon liner inserted into the gun.
  2. .030" wire needs high wire speed to weld Aluminum. Use only with Everlast welders rated for 600 IPM or greater and in MIG guns with blue polymer/teflon liner 10 ft. long or less.
