Cyclone Wire Feeder (Water-Cooled) FCS-203-ACWC  For Power i-MIG 353 DPi, view 1
Cyclone Wire Feeder (Water-Cooled) FCS-203-ACWC  For Power i-MIG 353 DPi, view 2
SKU# EV-FCS-203-ACWC
Single Spool MIG Wire Feeders
$699.00
  • Unit Weight: 45 lb
  • Shipping Weight: 48.98 lb
  • Unit Dimensions: 24 in × 10 in × 16 in
The FCS-203-ACWC wire feeder is designed to work with the Power i-MIG 353DPi welder. Water cooled connections help connect the MIG gun to the water cooler without having to use extensions. The cooler connects direct to the rear of the wire feeder via the water cooler umbilical lines supplied with the cooler. The wire feeder also has spool gun and push pull gun capability. The feeder may be operated with water cooled or air cooled torches.
Maximum Wire Feed Speed
600 IPM
Amperage Rating
400 Amps
Duty Cycle @ Amperage Rating
100%
Maximum Spool Weight
44 lbs
Spool Diameter(s)
12"
Number of Spools
One
Display
No Display
Number of Drive Rolls
Four
Stock Feeder Drive Roll Sizes
.035"/.9mm
.040-/ 1.0mm.045 .045" (.047 or 3/64")/1.2mm
.062" (1/16") /1.6mm
Supports Gun Types
Spool Gun
Air-Cooled Push Pull-Gun
Water-Cooled Push-Pull Gun
Air-Cooled Standard MIG Gun
Water Cooled Standard MIG Gun
Maximum Recommended Operation Distance from Power Source
75 Ft./Meters
Compatible With
Everlast
Main Case Material Type
Steel
Type of Operation (s)
Manual
