Welding Calculators |
Welding Calculators: |
| Are you not sure how to optimize your welder for its best performance? Then this simple, easy to use welding calculator can help you determine ideal settings for your welder. Keep in mind this is to be used as a general rule of thumb and is recommended as a starting point. Individual variables can influence exact setting.
Stick welding Calculators By selecting the material and the electrode you are using, Stick welding calculator will give you the Recommended Amperage Limit, Penetration, Position of Weld, Usage, Polarization and Electrode Description. |
TIG Welding Calculator Tig Welding Calculators provides the information about Tungsten Electrode Diameter,Polarity,Amperage Range,Torch Cup Orifice Diameter,Gas,Gas Flow Rate,Filler Metal Diameter and Welding Speed.Just by selecting the metal name and it's thickness you can know all details. |
MIG (Solid Wire) Welding Calculator MIG (Solid Wire) Welding Calculator tool provides information about Wire Size & Wire Feed Speed, Shielding Gas & Voltage Range, Amperage Range for both Short Circuit Transfer and Spray Arc Transfer. |
MIG (Flux Wire) Welding Calculator MIG (Flux Wire) Welding Calculator tool provides information about Wire Size, Wire Feed Speed, Shielding Gas & Voltage Range, Amperage Range for both Gas-Shielded Flux Cored and Self-Shielded Flux Cored. |
Welding terms finder Think a word in your mind in the terms we show. We will find it out and surprise you. Try our welding terms finder and have fun!!!! |
Welding is a complex process that requires training, skills, design expertise and patience.
EVERLAST respects these facts, and offers a welding calculator for this very purpose. By supplying details like the type of metal used and its thickness, then users can get the information to best optimize. There are welding calculators for Stick welding, TIG welding, MIG (solid wire) welding and MIG (flux wire) welding.
Diesel Generators | Multi-Purpose Units | Plasma Cutters | Welders | TIG Water Coolers | Welding Helmets | Consumables | Spare Parts | Accessories Welders Word Press | Welders News | Sitemap | Welder Blog | Welding Equipment Blogspot | Welding Supply Articles | Welding Calculators
