Spot Welding - 3 Easy Steps To Success
Spot welding is the method by which a spot can be melted and welded in a material
in a very short period of time. This will not affect the other portion
of the material. So it requires concentrated energy to a spot that it
is welded. The heat for welding is got from resistance to electric current
flow. The material is placed together under pressure exerted by electrodes.
The sheets are about 0.5 to 3.0 mm. in thickness. Copper alloy electrodes
are used to weld two sheets together in a spot. The heat that is obtained
is determined by the resistance to the electrodes and the amplitude
and duration of the current. If too much or too little energy is used
you will not get the desired result.
There are three steps in spot welding.
In the first step the electrodes and brought to the surface of the
metal and a little pressure is applied to it.
- The second step is when the current from the electrodes is applied for
a brief period of time.
- The third step is when the current is removed and the electrodes are
left in place so that the material can cool.
According to the material and its thickness, the electrode force and
the diameter of the electrodes, the weld time ranges from 0.01 seconds
to 0.63 seconds. To do spot welding you need tool holders and electrodes.
The general types of tool holding methods are - paddle type, light duty,
universal and regular off-set. The electrodes come in different shapes
and sizes according to different requirements and are generally made
of copper or other low resistance alloy. The work of the tool holders
is to hold the electrodes in place and also keep hold water hoses in
some cases to cool the electrodes while welding.
The two materials that are welded in spot welding are known as workpieces.
They must conduct electricity. When the current is removed from the
workpiece, the coolant holes in the center of the electrodes cool it.
Water or brine solution is generally used as a coolant.
Spot welding is used for many different types of
applications. It is used in different types of metal sheets. You can
see it in buckets. Aluminum alloys can be spot welded using powerful
and large welding transformers. It is greatly used in the automobile
industry. Here the sheet metal is welded to make a car. The work can
be completely automated by using robots. It is also used by orthodontists.
They use a small scale spot
welding equipment to resize metal molar bands. It is used
to make batteries - nickel-cadmium and nickel metal hydride. The battery
cells are joined by spot welding. Thin nickel straps are joined battery
terminals. If soldering were done, the batteries might get too hot,
while this will not happen in spot welding.
Care should be taken to see that the surfaces that have to be welded
are free of oil and dust. The spot that has to be welded should be easily
accessible and therefore importance should be given to the design of
the material that has to be welded.
Safety measures should be followed while spot welding, since there
will be a large amount of current and heat. Be sure to clamp the electrodes
tightly. The hands should be protected from the severe heat given out
while welding. The eyes should be protected from the intense light that
is given out during the welding process.
If you plan and have all the necessary material ready for spot welding
and take the necessary precautions before, during and after welding
is done, you will be able to do it without difficulty.
