Mig(Solid Core) Calculator:
All suggested settings are approximate.
Welds should be tested to comply to your specifications.
Welding metal used Thickness of the metal
Short Circuit Transfer
(generally used for thinner metals and out of position welding)
Wire Size & Wire Feed Speed:
Shielding Gas & Voltage Range:
Amperage Range:
Spray Arc Transfer
(generally used for thicker metals in the flat or slightly horizontal position)
Amperage Range:
Electrode Description:
Did you like this tool?Do you Want this tool in your site?Just copy the Html code below and paste it in the page you want to display our Stick Welding Calculator tool.
Select Text
MIG welding refers to metal active gas welding. The MIG (solid core) Welding Calculator is a worthy tool since it presents the necessary technical details for this type of welding. Initially you have to select the type of metal involved in the welding process and the thickness/welding type from corresponding drop boxes.[read more...]
