Mig Flux Cored Welding Calculator:
All the settings suggested were approximate only.
Welds should be tested to comply to your specifications.
Welding metal used Steel Thickness of the metal
Gas-Shielded Flux Cored
(An externally supplied gas or gas mixture is required)
Wire Size:
Wire Feed Speed*:
Amperage Range:
Shielding Gas & Voltage Range**:
Self-Shielded Flux Cored
(No need for shielding gas. Best for outdoor use in windy conditions. Hotter than solid wires)
Wire Size:
Wire Feed Speed*:
Amperage Range:
Voltage Range:
Did you like this tool?Do you Want this tool in your site?Just copy the Html code below and paste it in the page you want to display our Mig Flux Amperage Calculator tool.
Select Text
Another type of welding is MIG (flux core) welding, where you weld with a flux-cored wire feed welder.
The MIG (Flux Core) calculator is a useful tool complete with details. By clicking the Get Info button, you will get the necessary details for two categories: gas shielded flux core and self shielded flux cored. The wire size, wire feed speed and amperage range are common parameters for both categories. The parameter that differs is shielding gas and voltage range for gas shielded flux core, which is just voltage range for self shielded flux core.[read more...]
