Results 1 to 12 of 12
Thread: Everlast welding cart
  1. Default Everlast welding cart
    Here's my nearly completed multi process welding cart for my MTS211Si. Paint was the closest I could find off the shelf. Holds two tanks (for mig and tig), and has a large drawer. Built with 1" square tubing and 1/8" plate... it is solid for sure.
    (I tried attaching pics but the forums are acting strangely...)
    https://drive.google.com/file/d/0Byu...ew?usp=sharing
    I'll post better pics in this thread once the forum starts cooperating.
    Very nice, the paint matches perfectly. I'm glad to see someone else using stem casters.
    You're right about the forum acting weird, it's been getting worse for a few weeks.
    Thanks!
ID:	13124Click image for larger version.
    Sent from my SCH-I605 using Tapatalk
    Very nice indeed. I like the big drawer. Is that for dust free helmet storage?
    Great color match. too. I see you even did your mag gun holder.
    Thanks, and nice catch on the matching holder! Honestly, I haven't decided what's going in the drawer yet, but my helmet is definitely a top contender.
    I'm planning to grab better pics soon. It's hard to see, but there is a movable bar in the back securing the tanks. Two spin off knobs hold it down, and there is another position more forward if there is only a single bottle. The forward position is at a slight angle to keep the tank from moving side to side. I'm putting some pvc edge trim on all four side cable holders. That will be especially helpful where the wire spool access door opens. The casters were used since it will be "parked" in a tight spot sideways, allowing it to be stored out of the way.
    Thanks for looking.
    You can add another removable bar to the top back as well if you go for taller tanks. Color match is good too. Looks like you covered all the bases. Good job.
    Added the edging around the cable hooks. Here's some more pics:
    Dang, wish my place was that organized. Nice cart, like the way you can make it disappear againt the wall, I have locked rear wheels on mine.
    Thanks!
    Aug 2017
    Clifton, Texas
    Quote Originally Posted by mts211si View Post
    Optical illusion!
    The photo of the drawer pulled out looks WAAAY longer than the space where it fits!
    Jan 2019
    Montreal, Qc, Canada
    What's the paint you used to get this good of a match?
    Was it some off the shelf spray can or did you get a Pro shop mix you a pint?
    ________________________________
    Richard V.
    Canukystan Fabricobler, new to TIG...
    PowerTIG 200DV
    Paint code is RAL6018. Easy to match if you have a local paint store.
  1. Tig Welding Cart
    By Depdog in forum Other Custom Fabrications
    Last Post: 02-25-2014, 01:51 AM
  2. Welding Cart - Power Cart 250 - opinions?
  3. Everlast Welding Cart
    By RP62 in forum TIG Welding (GTAW/GTAW-P)
    Last Post: 10-28-2011, 02:56 PM
  5. welding cart
    By shawn in forum Other Custom Fabrications
    Last Post: 04-10-2011, 11:48 PM
