Page 1 of 9 123 ... LastLast
Results 1 to 20 of 169
Thread: Manipulating welder output with Arduino
    Default Manipulating welder output with Arduino
    My "foot pedal mods" thread went off into a pretty detailed discussion of potentiometers and stuff, and I suspect some people may have checked out. Since those people might be interested in this development, I'm making a separate post for it, even though it is on a similar topic. The attached video shows the (apparently) successful result of using an Arduino microcontroller to manipulate the output of the welder, in place of the pedal.
    The welder puts 2.7 volts through the pedal, and a potentiometer in the pedal redirects some of that voltage to pin 4 of the connector. In other words, as voltage on pin 4 goes from 0 to 2.7 volts, the welder's output goes from 0 to 100%. Therefore, by using the Arduino to put a voltage from 0 to 2.7 volts onto pin 4, we can simulate the effect of the pedal. This, in and of itself, would be completely boring, since the pedal does a fine job of it already. But the Arduino can be programmed to do much more interesting things. The main thing that got me started down this road was the desire to have a proper max-output limitation on the pedal. But I quickly realized that I could do other things, like implement 4T functionality, or... well, really anything I want. Want to practice travel speed? Okay. Set an arc timer where the arc will run for 10 seconds and you try to do exactly so many inches in that time. Whatever you can think of, really...
    One possible kink in the plan is that the Arduino doesn't have a true analog output. Rather, it uses pulse width modulation to emulate analog outputs. So the output pin is capable of being at either 5 volts or 0, and the Arduino cycles very rapidly between those two values to create a desired average voltage. The cycling is so fast that, in many cases, the difference between PWM and true analog is irrelevant, but the possibility of undesired effects can't be ruled out. If PWM turns out to be an issue, the workaround will be to use a digitally-controllable potentiometer chip instead of the Arduino's output pin.
    You could throw a cap in the mix or cap and zener and get a more of an analog looking signal?
    I've never used the Arduino's, but do they have a 3.3VDC version?
    You also might want to look at the Microchip 12F675 or 12F683. That would drop the cost to under 50 cents minus a cheap cell phone charger. But you would need a PIC programmer, but they can be had for probably what a single Arduino cost.
    What language does the Arduio use?
    Arduino uses an AVR microcontroller, and is programmed in C++. The main advantage over PIC, as I understand it, is that Arduino has been wrapped in many layers of fluffy padding, to make it more accessible to beginners. Those looking to "roll your own" can buy an AVR chip with Arduino bootloader sans the surrounding hardware for about $5 and still use the same code. I don't know what a plain AVR chip goes for.
    The Arduino does have a 3.3v signal that can be used with sensors or ICs that expect 3.3v supply, but the digital output pins are always referenced to 5v as far as I know. It would be nice if I could come up with a way to use the full 5v resolution and then step it down to 2.7v reference in analog, but practically speaking, I seem to have sub-1-amp resolution even going between 0 and 2.7 volts natively, so I'm not sure it's worth the effort.
    How is a PIC chip programmed? Native assembly, or high-level like C? Are there pre-constructed PIC packages that include support hardware like a regulated supply and so forth, or is that all DIY?
    PS: Mike, is there any reason to believe the PWM output from the Arduino will cause any distress to the welder? I really wouldn't think so, but there can sometimes be issues with HF transients when you feed an HF digital signal into an analog input, and I figure as long as I have the ear of someone who would know, I may as well ask.
    Only pre-wrapped little machine I use is the Raspberry PI, looking and a Beagal bone black to try next.
    On microcontrollers, I like PIC and Atmel. You can get a programer for the AVR and program it on the cheap too (no arduino requaired). But $5 is pretty cheap, what model Arduino is that?
    C is free for all pretty much. If you like simple, Rob Vun Kannon has RVKBasic (I talk to him about 6 months ago, old friend, do not think he is adding new chips anymore). For the pic, cheap as you can get, you can use GCBASIC (free again) and DOES PIC AND AVR. So you can pick (no pun) the chip you like. AVR has less quirks though.
    There are a couple of different levels you can get into. For $12, you can get an AVR microcontroller in a DIP receptacle on a pre-printed board.
    http://www.adafruit.com/products/174
    Here's the microcontroller chip alone, with bootloader pre-loaded, for $5.95.
    http://www.adafruit.com/products/123
    You know, you say you like Atmel and PIC, but correct me if I'm wrong--isn't the AVR chip made by Atmel? Are we actually talking about the same thing here?
    BTW, I realize that it's still more expensive, but you can get the cheapest Arduino boards for around $20-$25, and given that they come with power supply and serial-to-USB and other niceties all wired up and ready to go, I'm not sure it's actually worth it for most hobbyists to fool around with plain chips. Ultimately, you're still going to have to build a power supply, and maybe add a clock, and so forth, so you're going to end up adding back half the things you took out, and when you're done, you'll have spent $12-$15 perhaps, so for a cost savings of maybe $5-$10, you get to build all that stuff by hand? Meh.
    For example: Arduino Micro for $25
    http://www.adafruit.com/products/1086
    Here's the Teensy for $20, although it's rev. 2.0, and current rev. is 3.0 (that one goes for closer to $30).
    http://www.adafruit.com/products/199
    If I was building 1000 units, a cost savings of $5-$10 per unit would add up, but I'm not.
    How fast is the PWM output from the Arduino?
    You could do a simple RC filter to get the signal to be a better analog approximation.
    Use this calculator to estimate what the cutoff frequency and the voltage ripple would be.
    http://sim.okawa-denshi.jp/en/PWMtool.php
    You could make up a pulse feature fairly easily as well. Even make the high current, low current, and pulse frequency adjustable with Pots as analog inputs to the Arduino if you wanted.
    downslope or upslope could also be programmed into it if desired.
    Could get creative adn put a very low cost, microcontroller inline with the signal from a foot pedal. Put two or three switched on it for digital inputs, one being "no modification", one being one setting of pulse, and the third being another setting of pulse. Could be a $10 modification to make the PT185 a pulse capable machine.
    Hmmm...I have a PT185 sitting in the basement...hmmm...
    According to this link: http://arduino-info.wikispaces.com/A...-PWM-Frequency
    It appears the PWM output may only be 1khz.
    I happen to be working on an IR temperature sensor that outputs a PWM duty cycle variant signal at 1kHz and am looking at analog conversion options.
    I found this article with links to a schematic for using a 74HC4053 chip to pretty much eliminate ripple. The output update rate seems to match the input PWM update rate. Would be plenty for a pulse feature. I haven't really looked into it too much but I do have interest in trying to get the PWM output of the sensor I am working with into a usable analog output.
    http://www.edn.com/design/analog/432...most-no-ripple
    And it may be as high as 32 kHz. Thanks for the links to the ripple-removing filter. Very helpful.
    You could make up a pulse feature fairly easily as well. Even make the high current, low current, and pulse frequency adjustable with Pots as analog inputs to the Arduino if you wanted. downslope or upslope could also be programmed into it if desired.
    That's exactly the direction I'm going. I don't think that high-frequency pulse would be a good idea, because the machine isn't designed for it, so who knows what kind of stress might be put on the circuitry by yanking it up and down very quickly, but doing pulses maybe up to 30 Hz would probably be okay. Certainly no problem with an automated 1 Hz pulse to help the welder time their filler-rod dips. Also, 2T/4T functionality could easily be added.
    Currently, I'm building a box with pots on the front that basically mimics the front panel of a welder: upslope, downslope, pulse frequency, pulse balance, and so forth. My goal is to implement all of these functions using the Arduino's microcontroller.
    Yup. This is exactly where I'm going, although I think $10 modification may be a little ambitious. The real challenge is in writing the software to handle managing the output. If you were to go with static settings, it would be a little easier, because you could just program in a fixed output profile and run with it.
    A small update. The bugs seem to have been worked out of the output ramping algorithm.
    I spent a lot of time tracking down a bug wherein I mixed up the units of two variables. I track output internally as a percentage of max, so that the changes in output are independent of the welder's actual output range. But I also have to keep track of the actual voltage that I'm outputting, and somewhere in there, I mixed up a variable that holds one value for a variable that holds the other. Instead of setting output to 0.1 (10%), I tried to set it to 12 (1200%). Fortunately, my "set output" routine has bounds checking, and any value over 100% gets set to 100%. Any time you're sending voltage directly to hardware, put a lot of error checking in your code, kiddies...
    The ramping algorithm takes as an argument two variables: a target percentage to move to, and a time period over which to move. I originally had a start and end value for the "ramp", but I realized that the start value should always be whatever the welder was currently set to. There should never be an abrupt jump in the signal that is being fed to the welder, even though the welder probably would handle such a thing gracefully. If a specific output value is required as a starting point, the right thing to do is to elect to move the welder's output to that value over a chosen, short period of time. Then, you're forced to input the short period of time explicitly; you can never inadvertently move the welder's output without specifying over what time period the move should happen.
    Of course, you could always just specify 1 ms if you really wanted to, making the change effectively infinite.
    The algorithm you see demonstrated here will form the backbone of the entire program. Every change in welder output will be done via this algorithm: upslope, downslope, pulsing, etc... At least that's the plan so far. So even though it's kind of boring in a way, it's also kind of exciting. It's like looking at the block of an engine and thinking about the car that's going to be built around it.
    Yes, I like PIC and AVR chips (companies are Microchip and Atmel). Not into arm, moto, etc. ARM in OK on the Raspi using C though
    So arduino is preloaded software on the AVR and a sometimes a PCB? Why not just write the AVR code and burn it into the chip? Been doing it to long, I still have a STK-500 and a more current Dragon.
    32kHz should allow for a pretty smooth analog output.
    I wasn't suggesting altering the signal at a high rate, just using the high rate input to get a smooth signal. The Capacitor damping slows down the rate of change considerably so a higher input makes a better output.
    One thing you need to take into consideration, is that you will need the shield your circuit and verify that it is not affected by the HF and AC. Remember you have a rather powerful spark gap generator running right near your micro controller. Static tests will not tell you anything about that. HF TIG machines are known for messing up all kinds of electronics. I even had to replace a wired shop phone once, because it was unusable due to welding.
    You're 100% right on this. I did another project that involved using a UV sensor to detect the welding arc, and every third or fourth arc start, the Arduino would hang up, the LCD display would show random gibberish, and the whole thing would need to be power cycled. I have looked into how commercial products do it, such as arc timers that attach to the welding leads, and it seems that they basically sell two models--one for HF and one not. The HF one is required to be grounded. So basically, it seems that you need to put your electronics in a metal box and ground it, or HF is going to potentially play havoc.
    What makes it "Arduino" is several things. It's the bootloader on the chip, which simplifies the process of uploading code by allowing you to upload direct from the development environment via USB. The development environment also comes with a serial library that can be used to debug easily. "Arduino" also refers to a family of reference designs around the AVR chip, for which a set of accessory boards, known as "shields", have been created. So the Arduino Uno and its predecessors have female headers at a given spacing, and you could plug in an Ethernet shield, or a Wifi shield, or an SD card shield, or a speaker shield that had an integrated chip for decoding and playing back music, and so forth. These shields are combined with libraries written by members of the Arduino community, or companies like Adafruit, to make them easier to use and develop for. So instead of having to bit-bang a serial library to read from an SD card, I can just write "SD.initialize(); SD.read(0x1234);" Finally, "Arduino" refers to the community of users and companies that have sprung up around the design, who provide support for folks like me who barely know a transformer from a hole in the ground.
    So, in some sense you're right that it's "just preloaded software on an AVR," but it's also a lot more than that.
    Don't forget that, before I got an Arduino, I had zero experience coding microprocessors, so all those layers of fluffy padding were what made it possible for me to get over some of the learning curve in the first place. There are a lot of people who start out with the Arduino, then transition to a through-hole chip on a perf-board or custom PCB but still use the Arduino dev environment and bootloader, then eventually transition to a dedicated programmer and native AVR development environment, and move out of the "Arduino" scope entirely.
  1. DIY Arduino THC - Video
    Last Post: 09-26-2015, 05:49 AM
  2. DIY Arduino THC - Pass 2
    Last Post: 12-05-2013, 11:58 PM
  3. PP256 goes high and low with output
    By BlownBlueZ06 in forum Everlast Plasma Cutters (PAC)
    Last Post: 01-29-2012, 05:04 AM
  4. Thermal Arc 400GMS max output?
    By welderdude in forum General Welder Questions
    Last Post: 12-31-2011, 04:23 PM
  5. Power I-MIG 160 output on 120?
    By welderdude in forum MIG Welding (GMAW/GMAW-P/FCAW)
    Last Post: 06-21-2011, 02:08 AM
