Page 2 of 2 FirstFirst 12
Results 21 to 40 of 40
Thread: Power Tig 185 Micro Eratic Arc
    That bluing on the pipe shows it is Stainless Steel, or steel and not aluminum! The way you were discussing it was that it was aluminum with the AC settings you gave. The settings of AC balance and frequency are moot. It doesn't matter if it's on DC. And you close to 70-80 amps at the least for .095...and of course DC.
    HF point gaps would only affect it if you are not getting an arc transfer. They shut down after the start.
    How far off are you holding your tungsten? Think about the tungsten coming about the thickness of a credit card off the puddle.
    Make sure your gas is 100% argon. It is also possible it is contaminated.
    That makes perfect sense ... tighter arc and the three c's ... clean, clean, clean. I kinda figured the points would only effect start up which is why I didn't throw that out originally. The reason I mentioned DCEN was because I saw the picture wasn't aluminum and freq and bal was a moot point. I guess I should be more succinct in discussions ... my bad. He'll get it worked out I'm sure it's not anything major Everlast equipment is high quality. I'll butt out now and stop messing up this thread sorry.
    Powertig 200DX
    Lincoln 180c
    Hobart Handler 125
    Miller Thunderbolt 225
    Chicago Electric 130 DC Tig inverter
    Amvent 50 amp plasma cutter
    oxy-acetylene torches and tanks
    various mechanics and metal working tools
    Bead-flange roller, English wheel, ring roller etc, etc.
    Going as fast as I can with one eye closed. SYN-3 ET 778 ... AHDRA competitor, NHRA member ... like to play with fire and melt steel
    Thanks, It gets frustrating when you have used Miller ,Lincoln ,Thermal Dynamics and ESAB Equipment for years and not had any issues, Hell i even have a $99.00 Harbor Freight Flux 110 V Mig that has worked great for 3 years in pure outdoor hell.
    My 1988 Miller Matic 200 ( Purchased new) 0 Issues
    Miller Thunderbolt Stick same way
    ESAB 750I Plasma Should have never sold it.
    Leaning real hard on JUST RETURNING BOTH MACHINES AND STARTING OVER. I will Stew on this for a few days while on Vacation.
    Mark !!
    Its not stainless, its mild steel tubing. ? Were did aluminum come from, I tried it on some 6063 and it burnt nozzles and and cones.AC Balance is not working HF point gap was .042, plastic mount they were in is warped not true. the nut that holds the screw adjustment on the left side of the point assy was not tight , points also were not parallel with each other .
    Going in for service after 2 days of trying to get it to go , I am getting a bad felling about this deal.
    Attachment 7399
    The points dont' have to be dead on aligned to work...And the HF doesn't have anything to do with the actual welding arc.
    You discussed AC balance settings and frequency settings. AC is ONLY for welding aluminum, and then you showed a piece of pipe that wasn't aluminum. Are you welding AC or DC? If you are welding DC then the balance/frequency does not work.
    IF the nozzles burned up, then you had too much cleaning or you are not using pure argon gas...which it could be labeled as pure and is contaminated with CO2. That happens a great dealthese days. The intermittent properties you described sound like a gas issue.
    Give me a call and I'll be glad to go over things with you to help figure out what is going on. It does sound like a gas issue, from the burned up cones, to the "bee" sound in DC that is intermittent.
    Just went to Praxaire, Gas was good got another bottle same thing, Adjusted point started up but still no progress. DC on steel, AC on Aluminum. Digital at 40 will not heat 095 thickness material.
    I'm Done
    I'm Done
    The rule of thumb for TIG is 1 amp per .001 inch of thickness. That would put the requirement around 95 amps. I find that a little hot (I'd prefer 70-80 amps) but for some people it works...but 40 amps is way too low as it is... Especially if you are holding a long arc. You shouldn't be able to get a good puddle at that amperage. Are you on 120 or 240? The reading on 120 can be a little high as well, especially in the low end of the scale.
    It was on 240, just had a tig pro in to look at it, He does a lot of Stainless and straight copper and copper to steel tig work, he tried to weld with it and had no success , His coment Just Chinese Junk and Left.The machine is now in the box going back if someone will call back and give me a label.
    If NO LABEL BY END OF TODAY, alternative action will be taken.
    Well, I can assure you we will straighten anything wrong out. I know guys that have gotten bad products from other "majors" right out of the box as well. It happens from time to time. The best we can do is try to rectify it. At this point we don't know if it was something caused from internal shipping damage, or simply a loose wire, or something worse...As far as the alternative "action", please see the terms and policy you agreed to by purchasing our unit, and follow the protocol. We'll be glad to make things right accordingly.
    Companies like Thermal Arc and ESAB have considerable product made in China, and has been mentioned before we share a couple of factories...which points out that it could happen even with the best name. ALL companies are using imported parts (from the same part mfgr's in many cases we use) in the US assembled units...
  8. #28
    What he said! Hang in there my friend ... These machines are very well made. Things get banged around in shipping sometimes ...they will make it right!!! Everlast has a great rep for customer service ... I don't work for them ... I'm just a customer.
    Powertig 200DX
    Lincoln 180c
    Hobart Handler 125
    cbmkr
    new unit is out , very sorry for the troubles
    Oleg Gladshteyn
  10. #30
    Jun 2012
    Hutchinson Kansas
    Oleg that is what I call service. cbmkr posted at 3:07 PT185 won't work. Oleg posted at 4:42 new unit is out.
  11. #31
    Quote Originally Posted by bnun12 View Post
    BINGO! Like I said Everlast has a great reputation for customer service! I would stake my life on it!
    Powertig 200DX
    Lincoln 180c
    Hobart Handler 125
  12. #32
    Thank you guys .. !
    we try to do our best, in MOST cases we get it right
    Oleg Gladshteyn
  13. #33
    Have had a little time to play with the second machine ,I have worked around the one small issue for now,I tried the machine on some 1/8" aluminum and some 095 mild steel tube. I used 1/16" dia ( 3/32" would do better) rod for the Aluminum and steel, I tried 4 different amp settings on the alum settled in around 70-75 seemed best no pedal torch only.Ran the steel tube at 70 amps with the 1/16" rod and did just fine. Looks like a good machine and will do fine. I have some camera mounts to fab up today and will post a few pics along the way.
    ( Got my son in law under a hood and let him weld too) He picked it up pretty quick.
    Pictures don't look like much but we were just playing around with some scrap Click image for larger version.
Name:	everlast welds.jpg
  14. #34
    Glad to hear everything worked out well. Good customer service is so rare these days, it's great to see it in action. Good job Oleg! I really feel for any company that has to ship anything heavy for a box, but too light for a pallet. It seems like packages are just tossed around and damage happens way too much. I used to work at a place where we would often strap some things to pallets even if they could be lifted, just to change the way the shipping company would handle them. Cost more, but worth it. Of course we never went this far...
    http://www.theregister.co.uk/2008/07/23/enormouse/
  15. #35
    Yes, very good to hear things are for the better. Please keep us posted and do a review once you have some torch time.
    Miller 210 MIG
    Eagle 3-Cylinder Compressor
    Air Tools
    Bead Blast Cabinet
    Homebuilt Car Rotisserie
  16. #36
    We have one little detail to get worked out before i will give a full review, Oleg and i are working it out , i think everything will be fine.
  17. #37
    If I can diagnose and fix something with some help over the phone I'll take any day over trusting something that big to a courier - unless of course there isn't any other option. Anyone see that video where the courier truck driver tossed the flat screen over the fence to "deliver" it? Maybe that is why the package in Rambozo's link was necessary!
  18. #38
    That is the best way to try and solve a problem, My Daughter runs my old Ebay store ,i closed my retail store some years ago due to health issues,We dealt in Lost Freight , Overgoods as it is known in the business . It comes from all modes of delivery systems used in the US,The 2 Largest carriers that we all see and use everyday are the main suppliers to the business. We have found out if it is small less than 10 x 10 x 4" and weighs over 25 pounds it has a 70 % chance of making it across the country smaller and heavier get worse,Ship a 50 pound box of lead ingots and see how far they get. The automated systems have helped a lot of the loss and damage problems but the truck loading and hauling is the biggest. ?hit happens on the road and they have to deal with it , bad roads traffic accidents ,Airline delays ect. It gets very frustrating trying to ship an item back because of some small problem when you know the chances of it getting there in one piece or just lost in the shuffle do exist.
    A lot of the large box companies and even some Car manufactures, Computer repair and new item shipping are centralized in Main Hubs across the country owned by our 2 main shipping companies we see everyday, this cuts the shipping time down and makes for a better chance of the item getting where it has to go.You might return a laptop to Toshiba and it goes to a ?PS Hub for Repair and goes right back out finished by the computer company's repair tech..
    In the long run it all does work out in the end if you insure your items and the stuff that gets damaged or the box is torn , it gets put thru the system again and makes it to someone at a good price and everybody is happy.
    It just makes you Nervous when you know how the system works.
  19. #39
    Nova Scotia, Canada
    I once sent two ~2kg boxes measuring about 11"x11"x3" on a 30kg hard wood pallet. But it was food going to a grocery distribution centre. Between only receiving trucks and secure supply chains, it's the only way to get it done.
    Obviously a money loosing proposition for our company, but those are the sort of things you do for your customers...
    I use 1/16" for steel for just about everything. Obviously larger rod for larger stuff & building up & filling, but 1/16 is my go-to rod.
  20. #40
    So glad you got it worked out ... hope you have many years of use out of it.
    Powertig 200DX
    Lincoln 180c
    Hobart Handler 125
