Results 1 to 16 of 16
Thread: Adjustable Steady Rest
    Default Adjustable Steady Rest
    For all you young guys with a steady hand, don't bother reading this.
    This is for all of us older not-so-steady welders.
    I built this height adjustable steady rest so my welds don't look like I did them while I was attached to a concrete vibrator.
ID:	6630Click image for larger version.
ID:	6631Click image for larger version.
ID:	6632Click image for larger version.
    Everlast PowerTig 250EX
    PowerCool W300
    Millermatic 210
    Cut Master 50 Plasma
    Daewoo CNC Mill and Lathe
    Stuff
    Very clever!
    Powertig 200DX
    Lincoln 180c
    Hobart Handler 125
    and a bunch of other tools
    Necessity is the mother of invention... Looks really nice. I was surprised when I started reading about welding how important it was to get into a comfortable position. Now that I am looking into TIG it is even more so. Not sure how many of you do it, but it is mentioned to TIG weld when you are sitting down at a bench. I was worried about getting a lap full of sparks. It sounds like TIG does not make near the spatter as a MIG does.
    Shade tree MIG welder.
    Now a Shade tree TIG welder.
    Tig doesn't make any spatter or sparks if everything is going right.
    No it doesn't and if you go to Jodie's site www.weldingtipsandtricks.com he's been pitching something called a "tig finger" which slides onto your finger so you can rest it on your work piece and insulate yourself from the heat ... it's made of a fabric that allows you to slide your hand as you move down your bead. They sell for $10 and you can get a cut in price for buying multiple packs. I think I'm going to give them a try.
    Powertig 200DX
    Lincoln 180c
    Hobart Handler 125
    For some reason things don't always go right for me... So does that mean you TIG while sitting???
    I seen those... Actually I am another one that found the Everlast site from his.
    like your Aircrafter like to have one there really pricy
    you can make your own cheap , its just header wrap cloth .Titanium Exhaust/ Header Wrap - 15' : Titanium exhaust wrap, with LR Technology, is made from pulverized lava rock and stranded into a fiber material and is engineered to be stronger than typical wraps on the market today. It has the ability to handle higher heat for improved performance and durability and with a cool carbon fiber look! a hole roll for under 20 bucks Click image for larger version.
    Yes, all the tig welding I've done so far has been sitting.
    That a great idea. Let me guess, eBay? I'm guessing there because you are the master at finding useful stuff there ....
    was getting it from summit racing but is cheaper on ebay i use it alot for wrapping headers on cars and some boats http://compare.ebay.com/like/2209041..._lwgsi=y&cbt=y i buy it in 50 foot rolls
    Quote Originally Posted by 7FC_Driver View Post
    I really like this idea. By extension, maybe have something that can slide horizontally (but not too easily, of course) as an addition?
    If you cut it, do the ends start to unravel easily?
    do like i do a nylon strap a wheel caster to my wrist since it rolls lol wow just thinking not a bad though a platform to rest your wrist that rolls then could keep the rite distance when tiging
    Just thinking of an variation on 7FC_Driver's great idea of the "adjustable steady rest". Made me think of something like a ball bearing drawer glide moving in parallel to the bead you want to lay for the times you want to a straight weld.
    thinking the same like a slider
  1. Adjustable EP and EN?
    By MBfrontier in forum TIG Welding (GTAW/GTAW-P)
    Last Post: 08-08-2023, 12:06 AM
  2. New CK Steady Grip TIG Amptrol For Everlast 200DV
    By christian in forum TIG Welding (GTAW/GTAW-P)
    Last Post: 10-31-2015, 04:05 PM
  3. Mr. TIG with a CK Steady Grip TIG Amptrol for Everlast EXT Unit
    By christian in forum General Welder Questions
    Last Post: 10-12-2015, 03:25 AM
  4. Project #6, adjustable bending fork for tubing and flat bar, d.fisher
    By d.fisher in forum Other Custom Fabrications
    Last Post: 03-03-2012, 10:56 PM
  5. adjustable 3d Hand
    By Ram48 in forum Other Custom Fabrications
    Last Post: 03-13-2011, 12:08 PM
