Results 1 to 19 of 19
Thread: Tungsten dressing question
    Default Tungsten dressing question
    What is the best abrasive to dress tungsten tips with?
    Powertig 200DX
    Lincoln 180c
    Hobart Handler 125
    and a bunch of other tools
    I remember reading the following forum post the other day. Hope it helps you:
    http://www.everlastgenerators.com/fo...hlight=diamond
    Thanks undercut I'll follow the link ... I have been using my standard grinding wheel but I want to set up a wheel only for tungsten so I don't contaminate my tips also the direction the wheel is supposed to turn as you dress the tip concerns me too ur supoosed to point the tip in the direction of rotation and if the wheel is coarse it can grab the point and break off or even cause an injury.
    Powertig 200DX
    Lincoln 180c
    Hobart Handler 125
    Undercut ... I used the link and found some good info including an in depth download manual on tips ... this will help alot. I should have known to look at Jody's web site ... weldingtipsandtricks.com is awesome. Thanks!
    Powertig 200DX
    Lincoln 180c
    Hobart Handler 125
    I thought that thread would help you. There are a few other threads sprinkled throughout these forums but that one started by Rodsmachineshop seemed the most useful with the discussion and the link to weldingtipsandtricks. I'm glad it was able to help.
    i use a dedicated grinder I use a mini bench grinder also use the flex shaft tool to clean my mig torch ends when full of stuff http://www.google.com/products/catal...d=0CJcBEPMCMAAClick image for larger version.
    Sep 2011
    I use the same mini bench grinder to sharpen my tungsten as well. Then I use the scotch-brite wheel on the other end to polish it. Works well for me and was a very cheap setup.
    Brad George
    George's Welding & Repair
    Current Equipment
    Hobart Handler 120v MIG
    Thanks ... worth considering.
    Powertig 200DX
    Lincoln 180c
    Hobart Handler 125
    Thanks ... will look into it!
    Powertig 200DX
    Lincoln 180c
    Hobart Handler 125
    this works for me since i'm usually outside.Click image for larger version.
ID:	6523Click image for larger version.
ID:	6524Click image for larger version.
    Just got one of those grinders...works well and more handy and safe than the old bench grinder. I got a 10 pack of double sided, 1" diamond wheels on ebay for $8 and they work well so I'm happy with this set up
    Millermatic 251 with 30A
    Synchrowave 180
    Hobart 100 MIG
    lathe & RF45
    Power TIG 250EX
    Spectrum 625 X-TREME
    I've seen this before and thought about getting one ... maybe at some point in the future I'll do that.
    Powertig 200DX
    Lincoln 180c
    Hobart Handler 125
    that picture looks like the grind is across the tip? I thought that was N-G.. or is it my eyes..
    Everlast PowerPlasma70
    Hobart Ironman 230
    Lincoln A-D/C 225
    jakemateer.com
    Looks that way to me too
    Probably works fine for anything not on the lightest end of the amperage scale
    New to welding!
    Lots of Snap-On tools
    In need of more toys
    I think it's just the picture.
    From the manufacturer:
    "The long-life double-sided diamond grinding wheel produces longitudinal grinds for consistent welds, deeper penetration and less re-work."
    hello? why not take a minute to find out how to grind tungsten instead of seeing how many inane posts you can accumulate by resurrecting old threads.
    Hello back ... have done that ... long time ago ... have been trying to devise a way to keep a method specific to tungsten W/O having to spend money or having to change wheels on my grinder ... also appreciate the insight people have given while "resurrecting old threads". I think I have solved the issue to it's most cost effective end ... that is ... unless you can point out a reason not to ... your advise is absolutely welcome and encouraged. I just acquired a new drill press at no cost to me ... so what I think I'll do is install a sanding drum on my old one and use it exclusively for my tips. If you know a reason why I shouldn't do this ... I'm all ears. Have a great day my friend!
    Powertig 200DX
    Lincoln 180c
    Hobart Handler 125
    Mar 2012
    Remote S. Idaho
    Buy a 6 inch diamond lap from any of the dozen ebay vendors, $9.95 in any grit. 400 grit is about right. Sandwich it to your regular bench grinder wheel with the hold down washer and you have a dedicated diamond grinder for tungsten that gives linear grind marks.
    There is no safe direction to point an unsafe gun.
    PowerPro 205
    Hobart 250HF
    Powcon 300ST
    gas stuff
    14x60 Hercules Ajax lathe
    Gorton I-22 MastrMil
    Landis 6x18 surface grinder
    20" Powermatic bandsaw
    Ancient, big drill press
    350 pound anvil and a bunch of hammers
    If I can't fix it I can make it.....unrecognizable.
    Quote Originally Posted by JBnID View Post
    sounds like agreat idea ... I will look into it ... thank you
    Powertig 200DX
    Lincoln 180c
    Hobart Handler 125
  1. Question on possible tungsten dip contamination.
    By Frank in forum General Welder Questions
    Last Post: 06-25-2014, 05:30 PM
  2. Perhaps a silly question about tungsten...
    Last Post: 05-28-2012, 10:25 PM
  3. Buying some Tungsten..Question?
    By CGCINC in forum TIG Welding (GTAW/GTAW-P)
    Last Post: 12-12-2011, 05:30 PM
  4. Tungsten Question
    By SeanMurphy265 in forum TIG Welding (GTAW/GTAW-P)
    Last Post: 09-12-2011, 03:22 AM
  5. Tungsten grinder question
    Last Post: 09-06-2011, 05:53 PM
