Page 2 of 2 FirstFirst 12
Results 21 to 24 of 24
Thread: power pro 256 problem AGAIN
    7018 is the best to use for welding thicker metal i use the 6013 on rusty dirty metal good videos on stick welding and types of welding rod http://www.weldingtipsandtricks.com/stick-welding.html
    Default Electrode
    Quote Originally Posted by coonass View Post
    Well I ran it on stick and used the plasma everything seems right does anyone know of a good mild steel rod for a pp256 I used 6010 burn like arc gouge rods and 6011 leave a hard to remove flux. Any suggestions?
    7014 works well.
    Quote Originally Posted by DannyB1954 View Post
    7014 works well.
    Thanks I will pick some up next time I get electrodes.
    PowerPro 256
    Millermatic mig
    Miller 300D
    Profax spoolgun
    16 ton pipe bender
    36" bending brake/shear/slip roll
    48" bead blast cabinet
    Victor oxy/acet cutting rig
    Metal fabricator bender
ID:	6513Click image for larger version.
ID:	6514Click image for larger version.
    This came in a while back a cast aluminum handle on an old outboard..
    PowerPro 256
    Millermatic mig
    Miller 300D
    Profax spoolgun
    16 ton pipe bender
