Facts about the art of welding for beginners
In general welding is an art where two or more work pieces that primarily comprise of metals or alloys are joined together with the help of a molten solution that solidifies on cooling and forms the necessary bond between the work pieces. However, this is a simple definition for welding. The whole concept is primarily based upon joining metals or alloys in heavy industry manufacturing. And thus it is predominantly used in production across several industries and factories around the world. Welding is a very easy concept to learn and thus almost anyone could perform it with much ease after gaining proper guidance and knowledge. Welding as a part time job pays quite handsomely and thus many students while they are studying tend to work on factories or industries part time to sustain their lives as a student. It provides a wonderful opportunity for you to learn, master the art and also make a career out of it in future if you are interested in it. However, many industries prefer quality and experienced welders for handling their welding requirements as it is all about perfection and only an experienced welder could be a master of the art. The outcome of the process heavily depends upon how you do the procedure and it requires immense sufficient practice. Now let us take a theoretical look into the varieties of welding procedures.
tig welders
Tig welders
Predominantly most factories engage in MIG or TIG welding procedures for welding different kinds of metals and alloys. The procedure adopted largely depends upon the characteristics and properties of the metal that is needed to be welded.
MIG welding:
Also known as Gas Metal Arc Welding is a semi-automatic welding procedure in which continuous wire electrode and a shielding gas is fed through a welding gun. The wire electrode that is fed through is also consumable and thus for performing this kind of welding procedure, you need immense amount of raw materials depending upon what is needed to be welded. A constant voltage and current power supply is used for carrying out the task. And you have four different types of methods that can be used for the transfer of metal to form the bond. They are globular, short circuiting, spray and pulsed spray. Each of these methods has their own distinct properties, advantages and limitations.
TIG welding:
Also known as Gas Tungsten Arc Welding is an arc welding process that uses non-consumable tungsten electrode to produce the weld. It also makes use of a shielding gas for protecting the surroundings from contamination along with a filler metal. A constant source of power supply acts as the power supply unit for carrying out the task. This power is conducted across the arc through plasma.
Stick Welding:
Also known as Shielded Metal Arc Welding is an arc welding process that uses consumable electrode coated with flux to produce the weld. During the process as the weld is laid, the flux coating disintegrates giving off vapors that serve as a shielding gas.
All the details about these procedures, welders, safety equipments and other welding equipments could be found at www.everlastgenerators.com. Enjoy surfing!!!
