Essentials Of Multipurpose Units
Multipurpose units are very useful as they can perform multiple jobs
using one unit. This is not only space saving but also economical. These
units are extremely useful in factories and shops which require different
types of welding
machines. Now, they do not have to invest in two machines,
but can have one machine performing two or three different tasks. They
are suitable for harsh environments and can be used outdoors in construction
works, in farms, in factories dealing with various types of metals.
These machines are capable of maintaining constant current and having
concurrent processes for providing the right arc during welding. The
main advantage of a multipurpose power unit is that it can give you
a lot welding versatility in a single power source.
There are multipurpose units that
are three in one combining the work of a plasma cutter along with a
TIG and a stick welding unit. So,
in one unit you can benefit by having many different types of jobs done.
You also have a TIG welding machine that has all the features necessary from DC power to AC/DC 250 power in a single unit.
There are also multipurpose units that combine MIG
and Stick welding for welders
who need both these type of welding processes. This has CC/CV-MIG series
of machines.
There are MIG pulse welding machines
which have separate wire feeds for different models like 500A and 400A.
The 300A model is a 3 phase 400V. The 200A model has a compact single
phase.
There are multi-weld Stick welding machines
that can used to perform multiple tasks. They can handle DC 400, DC
600, DC1500, AC1200 etc. for welding purposes.
Also available in the market is a DC 400 multipurpose welding system
which has multi-process CV and CC capability, volt and amp meter, single
full output control, solid state circuitry that is useful for repetitive
procedures and has a long life, arc force control, arc control adjustment
and mode switching which is for choosing the right output characteristics.
These multipurpose units can perform
the different tasks that are essential in any welding situation. They
are all unique in their design and serve the purpose of welding. The
welding machine has to be convenient to handle, has
to perform the task properly and has to be economical. Now you need
not invest in many different types of welding machines. In one single
unit, you can get the advantages of all the types that you want. These
machines are useful for the beginner and the professional.
These multipurpose units are economical
and can do multiple jobs. They come with a warranty. The products are
of high quality and they perform their jobs efficiently. If an individual
or a company requires any new programs to be installed, that is also
done by the company.
The control panel of these units is self explanatory.
It is easy to use. The correct welding process can be chosen by the
person doing the job. The right application from the customized program
has to be used. The material thickness of the welding material has to
be checked before welding, the gas test done and also the wire inch
facility. The necessary synergic welding program has
to be selected. All the safety measures should also be taken care of.
If all these are done properly with care, the welding process can be
done easily. A multipurpose unit for welding purposes is definitely
a useful one.
