choose a welder category: |
input power: 1-phase |
possible applications:
garage, body shop, farm, ranch
light fabrication, maintenance, repair |
input power: 3-phase |
Coming Fall 2010
fabrication, manufacturing |
If you are considering MIG welders, then trying to choose which one that best suits your needs can be difficult if you are new to welding. It can also be an agonizing task even if you are experienced. For our basic selection of wire welders, we currently offer single phase inverter welding machines able to meet almost all common hobby, industrial fabrication and repair needs. Whether aluminum welders or stainless steel, or welding flux core wire our MIG welders have a perfect size for you....[read more...]
Everlastgenerators.com has various types of MIG Welders for sale. Everlastgenerators.com provides high quality welding and our MIG welders are no exception. MIG welding machines can be confusing to newbie welders but our discussion on what to look for in a MIG welder, and our complete round up of all mig welding machines currently available will demystify everything for you.
Metal Inert Gas (MIG) Welding is one of the easiest welding processes to learn. The purpose of all welders is to join similar types of metal together by melting them at a high temperature and adding filler into the molten puddle of metal for extra strength. MIG welders have the capacity of welding not only carbon-based steels but aluminum as well. MIG welders can be identified by the spool attachment that contains the wire used as the filler in the welding process. MIG welders range in size from large industrial machines that require three phase electricity to the home “buzz box” that can be plugged into any wall outlet.
How to select the right type of MIG Welding:
If you want to select the right type of MIG welder, you should know what type of input power is available:
- 1 Phase input power (typically 115 or 230 VAC) is found in homes and garages
- 3-Phase input power is common in industries.
- 1 phase input power is typically used in Garages, Body Shops, Farm, Ranch, Repair and light fabrication. Find the right MIG Welder for your home or single-phase shop.
- 1 & 3 phase is typically used for fabrication and light manufacturing. When you require flexibility go in for MIG machine that will perform in both single and three phase shops.
- 3 Phase input power is used for Manufacturing and fabrication process.
Function of MIG Welders:
- Buy MIG welders online with confidence. Everlastgenerators.com has all the information you require to buy MIG welders at lowest possible price.
- MIG welding process is very popular. Good MIG Welding techniques can produce excellent results. Properly made finished weld has no slag and spatter. MIG welding can be used for various material types – steel, aluminum, stainless steel and on wide range of material thicknesses.
Stay safe while MIG Welding:
- Wear these safe equipments before MIG welding. MIG welding is a fun hobby and can be lucrative as well. It is very dangerous if not done correctly. So wear these equipments before MIG welding.
- Wear safet y gloves. They can protect your hands from hot metal and ultraviolet rays.
- Wear fireproof overalls. Fireproof overalls can protect you from hot sparks and molten metal.
- Use proper ventilation.
- Keep a fire extinguisher near your work area
- Buy a pair of high leather work boots.
- Wear welding hoot to protect your eyes from harmful UV rays. Two types are available: auto-darkening hoods and fixed shields which stay dark all the time.
Buy MIG welders from everlastgenerators for best quality.
Benefits of Mig welding:
- • The continuously fed electrode of mig welding makes it much faster compared to other welding process such as TIG or Stick.
- • Since flux is not used, mig welding produces a smooth, clean, spatter free and high quality welds. This reduces the total welding cost since no further cleaning is required.
- • The welding process can be either semi automatic or fully automatic.
- • With mig welding, it is easier to weld both thicker and thinner materials effectively which proves its versatility.
- • It has higher disposition rates than shielded metal arc welding (SMAW).
- • Distortion is reduced considerably in mig welding since it involves high arc travel speeds.
[Collapse...]
Diesel Generators | Multi-Purpose Units | Plasma Cutters | Welders | TIG Water Coolers | Welding Helmets | Consumables | Spare Parts | Accessories Welders Word Press | Welders News | Sitemap | Welder Blog | Welding Equipment Blogspot | Welding Supply Articles | Welding Calculators
